  2. Other
  3. Other
Types of Authentication
  • 26 October 2025 at 14:10
    In IT there are so many authentication options. Here are the 10 commonly used ones.
    Authentication
    Password-Based
    Users enter a username and password.
    Two-Factor (2FA)
    Combines a password with a second factor like a mobile code or app.
    I just can recommend to add this to your accounts if possible.
    Multi-Factor (MFA)
    USes multiple factors, such as a password, a smartphone and biometrics.
    Biometric
    Uses unique biological characteristics like fingerprints, facial recognition or iris scans.
    Token-Based
    Users posess a physical device (token) that generates a code.
    Luxtrust in Luxembourg removed this one for banking systems as it is to unsecure.
    Certificate-Based
    Digital certificates authenticate users - often used in enterprise environments.
    Single Sign-On (SSC)
    Allows users to log in once and gain access to multiple systems without re-authenticating
    Smart Card
    Users authenticate by inserting a smart card into a reader and entering a PIN.
    OAuth/OpenID Connect
    USers authenticate via third party services (like Facebook or Google) to access different services.
    Behavioral
    Analyzes patterns un user behaviour (like typing speed, mouse mouvements and so on) to authenticate users.
    This is often used on sites to avoid sign in tries with a bot.
  • 44 Today
  • 44 This Week
  • 421 This Month
  • 60.449 This Year
  • 60.449 Total
Last updated: 2 November 2026 at 02:36
