Suspend/Resume Bitlocker
  • 26 October 2025 at 13:16
    Sometimes you need to suspend your Bitlocker Encryption in order to change some hardware.
    Here a 2 ways to do it - you need admin rights to do it.
    Powershell
    Open Powershell as admin an run the following command to suspend the Bitlocker Encryption.
    Suspend-Bitlocker -MountPoint "C:" -RebootCount 0
    Open Powershell as admin an run the following command to resume the Bitlocker Encryption
    Resume-Bitlocker -MountPoint "C:"
    CMD
    Open CMD as admin an run the following command to suspend the Bitlocker Encryption
    Manage-bde -Protectors -Disable C: -RebootCount 0
    Open CMD as admin an run the following command to resume the Bitlocker Encryption
    Manage-bde -Protectors -Enable C:
    Additional info
    You may have noticed that both have an option with RebootCount. This is used to say to the system that after x reboots the system will automatically reactivate itself.
    The value here can be maximum 15.
