  3. Network
Insecure vs Secure Ports
  • 25 October 2025 at 09:18
    There are some default Ports used when working on a network/server but most of these ports exists in a default way and a secure way. Here are some essential ports listed with it's default number and it's secured number.
    Insecure Port
    Protocol
    Secure Port
    Protocol
    FTP
    File Transfer Protocol (FTP) sends the username and password using plaintext from the client to the server.
    22
    SFTP
    Uses encryption to protect the user credentials and packet of data being transferred.
    23
    Telnet
    All information to & from the host on a telnet connection is sent in plaintext & cand be intercepted by an attacker.
    22
    Secure Shell
    Secure Shell (SSH) on port 22 uses encryption to ensure that traffic between the host and terminal is not sent in plaintext format.
    25
    SMTP
    Simple Mail Transfer Protocol (SMTP) is the default for sending email messages. Since it is unencrypted, data contained within the emails could be discovered by network sniffing.
    587
    SMTP
    The secure alternative is to use port 587 for SMTP using Transport Layer Security (TLS) which will encrypt the data between the mail client and the mail server.
    37
    Time
    Time Protocol may be in use by legacy equipment and has mostly been replaced by using port 123 for Network Time Protocol (NTP).
    123
    NTP
    NTP on port 123 offers between errorhandling capabilities, which reduces the likelihood of unexpected errors.
    53
    DNS
    Domain Name Service (DNS) is still used widely.
    853
    DoT
    However using DNS over TLS (DoT) on port 853 protects DNS information from being modified in transit.
    80
    HTTP
    Hyper Text Transfer Protocol (HTTP) is the basis of nearly all web browser traffic on the internet. Information sent via HTTP is not encrypted and is susceptible to sniffing attacks.
    443
    HTTPS
    HTTPS using TLS encryption is preferred as it protects the data in transit between the server and the browser.
    143
    IMAP
    Internet Message Access Protocol (IMAP) is a protocol used for retrieving emails. IMAP traffic on port 142 is not encrypted and susceptible to network sniffing.
    993
    IMAP
    The secure alterative is to use port 993 for IMAP which adds SSL/TLS security to encrypt the data between the mail client and the mail server.
    445
    SMB
    Server Message Block (SMB) is used by many versions of Windows for accessing files over the network. Files are transmitted unencrypted.
    2049
    NFS
    Network File System (NFS). Although NDS can use encryption it is recommended that NFS not be allowed through firewalls either.
    389
    LDAP
    Lightweight Directory Access Portocol (LDAP) is used to communicate directory information from servers to clients. Since LDAP is not encrpyted it is susceptible to sniffing and manipulation attacks.
    636
    LDAPS
    Lightweight Directory Access Portocol Secure (LDAPS) adds SSL/TLS LDAPS Security to protect the information while it is in transit.
