  5. PowerShell
Bind & DDNS & PowerShell
  • 26 October 2025 at 12:35
    Den Key erstellt Ihr euch über SSH mit folgendem Befehl
    Achtung: Domainname natürlich mit eurem ersetzen!
    ddns-confgen -a hmac-sha512 -z Domainname
    Example: Named.conf
    // named.conf
    // Provided by Red Hat bind package to configure the ISC BIND named(8) DNS
    // server as a caching only nameserver (as a localhost DNS resolver only).
    // See /usr/share/doc/bind*/sample/ for example named configuration files.
    options {
        listen-on port 53 {
                any;
        // listen-on-v6 port 53 { ::1; };
        // filter-aaaa-on-v4 yes;
        directory     "/var/named";
        dump-file     "/var/named/data/cache_dump.db";
        statistics-file "/var/named/data/named_stats.txt";
        memstatistics-file "/var/named/data/named_mem_stats.txt";
        secroots-file    "/var/named/data/named.secroots";
        recursing-file    "/var/named/data/named.recursing";
        allow-query {
            any;
        allow-transfer {
            EDITED;
        notify yes;
        also-notify {
            EDITED;
         - If you are building an AUTHORITATIVE DNS server, do NOT enable recursion.
         - If you are building a RECURSIVE (caching) DNS server, you need to enable
           recursion.
         - If your recursive DNS server has a public IP address, you MUST enable access
           control to limit queries to your legitimate users. Failing to do so will
           cause your server to become part of large scale DNS amplification
           attacks. Implementing BCP38 within your network would greatly
           reduce such attack surface
        recursion yes;
        dnssec-validation auto;
        managed-keys-directory "/var/named/dynamic";
        geoip-directory "/usr/share/GeoIP";
        pid-file "/run/named/named.pid";
        session-keyfile "/run/named/session.key";
        /*  https://fedoraproject.org/wiki/Changes/CryptoPolicy  */
        include "/etc/crypto-policies/back-ends/bind.config";
        forwarders {
            EDITED;
            8.8.8.8;
            8.8.4.4;
        // dnssec-enable yes;
    logging {
        channel default_debug {
            file "/var/log/named.run";
    zone "." IN {
        type hint;
        file "named.ca";
    include "/etc/named.rfc1912.zones";
    include "/etc/named.root.key";
    key rndc-key {
        algorithm hmac-sha256;
        secret "EDITED";
    key "ddns-key.dyndns.datateam.center" {
            algorithm hmac-sha512;
            secret "Euer generierter Key";
    controls {
        inet 127.0.0.1 port 953 allow { 127.0.0.1; } keys { rndc-key; };
    server EDITED {
    zone "datateam.center" {
        type master;
        file "/var/named/datateam.center.hosts";
        also-notify {
            EDITED;
        notify yes;
        update-policy {
              grant ddns-key.dyndns.datateam.center zonesub ANY;
        allow-transfer {
            127.0.0.1;
            EDITED;
    Display More
    I edited some things and replaced them with EDITED - so be careful
    What is actually just added is the following:
    Unter der Zone kommt folgendes:
        update-policy {
    You will receive exactly what is entered when you generate your key.
    Example: Key File
    PowerShell Script
    PowerShell
    Get full info:
    $providerinfo = Invoke-RestMethod  http://ipinfo.io/json
    Param (
        [String]$KeyPath = "C:\dyndns\dyndns.datateam.center.key",
        [String]$NSScriptPath = "c:\dyndns\nsupdate.txt",
        [String]$NSUpdatePath = "C:\dyndns"
    begin {
        #Gather status of system IP Addresses, DNS Servers, and domains
    $myip = (Invoke-WebRequest -uri "https://api.ipify.org/").Content
    $servername = "ns1.datateam.center"
    $dnszone = "datateam.center"
    $hostname = "holodeck.$dnszone"
    process {
                        $script = "update delete $hostname
    update add $hostname. 60 A $myip
    end {
        $script | Out-File -FilePath $NSScriptPath -Encoding "ascii" -Force
        Start-Process -FilePath (Join-Path -Path $NSUpdatePath -ChildPath "nsupdate.exe") -ArgumentList "-d -k `"$KeyPath`" `"$NSScriptPath`"" -Wait -NoNewWindow -RedirectStandardError "c:\dyndns\nsstderr.log" -RedirectStandardOutput "c:\dyndns\nsstdout.log" -WorkingDirectory $NSUpdatePath | Out-Null
    Display More
    Here I created the dyndns directory on C: on a Windows computer.
    Below I copied the DLL files and nsupdate.exe from the ZIP file from the Bind DNS server.
    dyndns.datateam.center.key is the file with the generated key. You can name it whatever you want, you just have to adapt the PowerShell file 🙂
