  3. Network
The OSI Model with possible protocols
  • 25 October 2025 at 09:14
    No.
    Layer
    Device
    Implementations
    Protocols
    7
    Application
    Provides services directly to user applications.
    Identifies communication partners, identifies quality of service, considers user authentication and privacy and determines if adequate ressources are present.
    Gateway
    SMB
    HTTP
    SMTP
    FTP
    SNMP
    Telnet
    AppleTalk
    6
    Presentation
    Performs data transformations and services including formatting, compression and encryption services to provide a common interface for user applications.
    Gateway
    Redirectors
    HTTP
    FTP
    Telnet
    SMTP
    AFP
    TDI
    5
    Session
    Establishes, manages and terminates connections between applications at each end.
    Allows 2 applications to communicate over a network by opening a sessions and synchronizing the involved computers.
    Gateway
    NetBEUI
    TCP
    UDP
    SPX
    4
    Transport
    Provides transparent transfer of data between end systems by insulating layers 5-7 from complexities of layers 1-3.
    Responsible for end to end error recovery and flow control and ensures complete data transfer.
    Gateway
    IP
    IPX
    NWLink
    NetBEUI
    3
    Network
    Establishes, maintains and terminates network connections.
    Handles traffic management including addressing, routing, switching, forwarding, local paths and virtual circuits, error handling, congestion control and packet sequencing.
    Router
    Brouter
    IP
    IPX
    NWLink
    NetBEUI
    2
    Data Link
    Divided into two sub-layers:
    The Media Access Control (MAC) sub layer controls how a networked computer gains access to the data and permission to transmit it
    The Logical Link Control (LLC) sub layer controls frame synchronization, flow control and error checking.
    Switch
    Bridge
    Router
    Ethernet
    PPP
    HDLC
    Physical
    Controls transmission of the bit stream data over the physical medium.
    Standards for this layer address transmission at the electrical and menchanical level including signal voltage swing, voltage duration, etc.
    Multiplexer
    Repeater
    Ethernet
    Token Ring
    FDDI
