Resize EFI partition
  • 27 July 2026 at 10:32
    Instead of resizing the original EFI partition (which is risky because it is located at the beginning of the disk), we migrate the system to a new, larger EFI partition.
    1. Create a new EFI partition
    Open an elevated Command Prompt and run:
    diskpart
    list disk
    select disk X          (replace X with your system disk)
    list partition
    Make sure you have unallocated space available (≥350 MB recommended, 500 MB–1 GB preferred).
    Then create the new EFI partition:
    create partition efi size=500
    format quick fs=fat32 label="System"
    assign letter=Z
    exit
    Explanation:
    • create partition efi → creates a GPT EFI System Partition
    • fs=fat32 → required by UEFI specification
    • size=500 → 500 MB recommended (adjust if needed)
    • assign letter=Z → temporary drive letter for setup
    2. Generate fresh boot files in the new EFI
    Do not copy the old EFI manually (the BCD file is locked while Windows is running).
    Instead, create new boot files:
    bcdboot C:\Windows /s Z: /f UEFI
    You should see:
    Boot files successfully created.
    3. Redirect firmware boot manager to the new EFI
    bcdedit /set {bootmgr} device partition=Z:
    bcdedit /set {bootmgr} path \EFI\Microsoft\Boot\bootmgfw.efi
    4. Reboot and verify
    Reboot the system.
    If Windows boots normally, the system is now using the new EFI partition.
    You can confirm with:
    bcdedit
    5. Cleanup
    After confirming everything works:
    • Delete the old 100MB EFI partition
    • Optionally expand the new EFI partition further
    • Resume BitLocker (if it was suspended)
