  4. MacOS
MacOS - Duplicate Icons after restore
  • 17 June 2026 at 13:11
    Sometimes it may happen that after you reinstall your Mac but don't recover a backup icons suddenly 2-3 times.
    This is a known bug and can easily be fixed with a simple command.
    Open the Terminal app and enter this
    defaults write com.apple.dock ResetLaunchPad -bool true; killall Dock
    If this doesn't directly work you may switch off your Mac (REALLY SWITCH OFF) and wait for about 30 seconds. Than you can switch on again.
    If that doesn't help you may really have multiple copies of the apps in your application folder.
