  3. Software
JNLP files not opening
  • 26 October 2025 at 11:36
    f you have the issue that JNLP files don't open correctly anymore with Java simply copy the code below in a .reg file and import it to your registry.
    Pay attention that this example here is for the Java 8 Update 201 (last free version) version and you may need to update the path to your jp2launcher.exe file.
    Windows Registry Editor Version 5.00
    [HKEY_CLASSES_ROOT\JNLPFile]
    @="JNLP File"
    "EditFlags"=dword:00010000
    [HKEY_CLASSES_ROOT\JNLPFile\Shell]
    [HKEY_CLASSES_ROOT\JNLPFile\Shell\Open]
    @="&Launch"
    [HKEY_CLASSES_ROOT\JNLPFile\Shell\Open\Command]
    @="\"C:\\Program Files (x86)\\Java\\jre1.8.0_201\\bin\\jp2launcher.exe\" -securejws \"%1\""
    [HKEY_CLASSES_ROOT\jnlp]
    @="URL:jnlp Protocol"
    "URL Protocol"=""
    [HKEY_CLASSES_ROOT\jnlp\Shell]
    [HKEY_CLASSES_ROOT\jnlp\Shell\Open]
    [HKEY_CLASSES_ROOT\jnlp\Shell\Open\Command]
    [HKEY_CLASSES_ROOT\.jnlp]
    @="JNLPFile"
    "Content Type"="application/x-java-jnlp-file"
    Display More
