DYMO LetraTag 200B
  • 2 January 2026 at 08:41
    Neutral
    The DYMO LetraTag 200B is a portable, Bluetooth-enabled label maker that connects wirelessly to your smartphone or tablet via the DYMO LetraTag Connect app for easy label creation and printing, ideal for home and office organization, offering various fonts, icons, and boxes on different tape types, including plastic, paper, and iron-on fabric, with its compact design and automatic connection making it convenient for on-the-go use.
    Quality
    Easy to use
    Print Speed
    3 out of 5
    App
    3 out of 5
    • Dimensions: 120mm x 120mm x 45mm
    • Color: Black
    • Software Compatibility: Android v10.0 (or higher) / Apple iOS v13 (or higher)
    • Label Compatibility: LetraTag Tapes
    I thought it was a good device for replacing my normal Dymo Label Printer but I didn't expect to get such a device in our actual time that only works exclusively with batteries. No possibility to connect an external power supply - nothing.
    Than you need a special app for this device, the normal DymoConnect App doesn't work, you need LT Connect.
    And the worst: On every single print the app reconnects to the printer - so you loose so many time due to that.
    Not even an auto cut function is included - so also after every print you have to cut your label.
    For me at the end it's a downgrade from the one I already own - the only positive is that I can use my phone to print which is more convenient for typing but for the rest... At least it takes the same tapes as my old device...
