Govee 38cm RGBICWW Smart Ceiling Light Pro
  • 31 December 2025 at 12:40
    Introducing the Govee Smart Ceiling Light Pro! With its RGBIC+WW technology magic, your room will transform into a vibrant wonderland. Bigger in size, it blankets your space with dazzling colors and effects.
    • Planar Colorful Lighting Effect: The internal lamp beads of the main light are arranged in five concentric circles. Independent control for each light, a total of 120 segments, creating more detailed and dynamic effects.
    • High-Intensity Lighting: With a brightness of 4300lm, 79% brighter than normal lighting, it's suitable for multi-scene lighting.
    • Simple Installation: This 15-inch flush mount ceiling light can be installed in just five easy steps, saving time and effort.
    • Multiple Scene Modes & Music Modes: Includes 66+ scene modes, allowing you to DIY any lighting effect.
    • Smart Lighting Control: Adjust your light with a voice command. Supports Alexa, Google Assistant, and Matter.
    • Modern Style: Low-key fashion with its white simple round appearance, suitable for a modern home style.
    Quality
    Easy to use
    iPhone App
    Brightness
    Different Modes
    Music Mode
    Model → H60A6
    Product Title → Govee 38cm RGBICWW Smart Ceiling Light Pro
    Main Light Displaying Technology → RGBIC+WW
    Back Light Displaying Technology → RGBICWW
    Lumens → 4300lm
    Color Temperature → 2700k-6500k
    Wattage → 48.5W
    App Connectivity → 2.4GHz Wi-Fi + Bluetooth
    Control Methods → Govee Home, Voice Control, Matter
    Energy Class → F
    I was so impressed when switching this light on. It's so bright I wasn't prepared to it.
    Such a light falls and stands with it's app and the Govee Home App is great. You have so many scenes, colors and so on. Even the light can react to the music (with the help of the micro of your phone).
    Installation is very easy but don't use the screws you get with the package - they are a mess. Simply take your own or buy some good ones...
    For the rest myself I gonna replace every light in my apartment with this one. Of course not for the full price of 98,32€ but when they have some actions when I bought mine for 74,99€.
