  4. Linux
Linux Cheatsheet (for beginners)
  • 26 October 2025 at 10:49
    Command
    ls
    lists contents of a directory just like dir under DOS
    cat
    concatenate and print files
    grep
    searches for specific results with pattern
    clear
    clear the terminal
    cd
    change directory
    pwd
    print the working directory
    mkdir
    creates (make) a directory
    rmdir
    delete (remove) a directory
    man
    prints the manual pages of a specific tool
    which
    returns the path to an executable
    find
    searches for files in a directory hierarchy
    locate
    searches for files in a system using a prebuilt database
    who / whoami
    display all logged in users / current user
    id
    returns user ID
    chmod
    changes permissions and mode flags of a file or directory
    uname
    prints operating system's name (unix name)
    ifconfig
    network interface configuration of the system
    ip
    display and configure network parameters
    sudo / su
    executes a command as a different user
    by default the superuser
    open a sessions a s superuser
    ps
    lists the running processes status
    kill
    sends a kill signal to a process
    head
    view the first lines of any text
    mv
    move files
    cp
    copy files
