Rode Wireless Go 2 & Rode Central
  • 29 October 2025 at 12:21
    The Wireless GO II is a versatile and ultra-compact dual channel wireless microphone system consisting of a dual channel receiver and two transmitters.
    Power Consumption
    Weight
    Desktop Software
    iPhone Software
    Background filtering
    1 out of 5
    These microphones are really great. I always used the first version of them but just with 1 channel. I already liked those. But as my wife joins much more often now and I needed one that I also can connect to my PC if needed I swapped them for the new 2.
    It's insane how they get improved and how many new features they have like split or joined channel, direct recording on the micro and so one.
    And of course, what is great too, is that I can connect over USB-C to my iPad, my PC etc. and it simply works.
    Introductory price (2023)
    349€
    Acoustic Principle
    Pre-polarised pressure transduce
    Polar Pattern
    Omnidirectional
    Frequency Range
    50Hz – 20kHz
    Maximum SPL (Mic)
    100 dB SPL (1kHz @ 1m) dBu
    Maximum Input Level (3.5mm)
    -20dBV
    Microphone Preamp Gain
    20dB
    Equivalent Noise Level (A-Weighted)
    22dBA
    Power Requirements
    In-built rechargeable lithium-ion battery
    charged via USB 5V, 0.3A
    Operating Time
    Up to 7 hours
    Analog Inputs
    3.5mm TRS (lavalier microphone input)
    Analog Outputs
    3.5mm TRS
    Transmission Range
    200m (line of sight)
    Computer Connectivity
    USB Type-C
    Operating System Requirements
    macOS 10.11 above
    Windows 10 and above
    Weight (grams)
    TX: 30g
    RX: 32g
    RODE
