SD Cards
  • 28 October 2025 at 13:45
    There are many different classes etc. for SD cards and here I collect the data over it on one page
    First, there was the speed class, which went from Class 2 to Class 10. Then there was the UHS Speed Class, where the cards fall into either U1 or U3. More recently, there’s a newer system, the Video Speed Class, that uses categories like V30, V60, and V90.
    And now the SD Association has come out with a new rating system specifically to categorize suitability for SD and microSD cards in application-heavy uses. It’s known as the Application Performance Class Specification, and it’s written in the form of A1 or A2.
    So, we start with these first
    Pictograph
    Minimum Random Read
    Minimum Random Write
    Minimum Sustained Sequential Write
    Class 1 (A1)
    1500 IOPS
    500 IOPS
    10 MB/s
    Class 2 (A2)
    4000 IOPS
    2000 IOPS
    10 MB/s
    Speed Class
    Speed Class
    Minimum Sequential Write Speed
    2
    2 MB/s
    4
    4 MB/s
    6
    6 MB/s
    8
    8 MB/s
    10
    10 MB/s
    UHS Speed Class
    UHS Speed Class
    10 MB/s
    3
    30 MB/s
    Video Speed Class
    Video Speed Class
    V6
    6MB/s
    V10
    10MB/s
    V30
    30MB/s
    V60
    60MB/s
    V90
    90MB/s
    x Speed Factor
    Some manufacturers, like Lexar, also set an X Speed on their cards. To better have an overview of them here also a small table about it.
    x Speed Factor
    100x
    15 MB/s
    120x
    18 MB/s
    133x
    20 MB/s
    150x
    23 MB/s
    200x
    30 MB/s
    400x
    60 MB/s
    600x
    90 MB/s
    633x
    95 MB/s
    1000x
    150 MB/s
    1400x
    210 MB/s
    1800x
    270 MB/s
    2000x
    300 MB/s
    2500x
    375 MB/s
    3000x
    450 MB/s
    4000x
    600 MB/s
    5000x
    750 MB/s
    SD Card Bus Type
    But pay attention that there is a UHS bus type too which is not to be compared with UHS speed...
    SD Card Bus Type
    Maximum Speed
    UHS-I
    104 MB/s
    UHS-II
    312 MB/s
    UHS-III
    624 MB/s
    SD Express
    985 MB/s
    There is a certain amount of backwards compatibility between UHS-I and UHS-II. You can use either card type in any camera or SD card reader that accepts an SD card. The critical thing to understand is that both the device and the SD card must be UHS-II compatible if you want to unlock the additional speed benefits of the UHS-II interface.
    Types of SD Card
    SD Card Type
    Capacity
    SD
    128 MB → 2 GB
    SDHC
    4 GB → 32 GB
    SDXC
    64 GB → 2 TB
    SDUC
    up to 128 TB
    What do you need?
    At the end we just need to mention what speed you need for what :smiling_face:
    I just mention the starting speed - all above is of course better
    8k Video → 30 MB/s → U3 → V30
    4k Video → 6 MB/s → Speed Class 6
    1080p Video → 4 MB/s → Speed Class 4
    Standard Video → 2MB/s → Speed Class 2
    So, as you see if you only have cards with Speed Class x you can't record 8k videos as example but should be enough, starting at class 6, for 4k videos. Of course, I recommend using U3 / V30 cards for 4k recording to be sure.
