  3. Network
Reverse DNS
  • 26 October 2025 at 10:29
    If you ever needed a Machine Name for an IP Address you can simply try this PowerShell command (always run as administrator).
    $ComputerIPAddress = '10.10.10.10'
    [System.Net.Dns]::GetHostEntry($ComputerIPAddress).HostName
    There is an alternative to get more information while connection to the Active Directory (if available).
    import-module activedirectory
    Get-ADComputer -property * -filter { ipv4address -eq $ComputerIPAddress }
