  5. PowerShell
PowerShell Sites, Commands & Aliases
  • 27 October 2025 at 08:29
    I collected several Websites, Commands and Aliases together and but them for you in some tables.
    PowerShell WebSites
    Name
    URL/Link
    Microsoft PS Modules
    A list of popular PowerShell modules presented by Microsoft
    URL/Link
    Microsoft References
    Windows PowerShell 4.0 and Other Quick Reference Guides
    URL/Link
    PowerShell Cookbook
    A very interesting book about PowerShell 4 - The one is use to learn :smiling_face:
    URL/Link
    PowerShell Gallery
    The central repository for sharing and acquiring PowerShell code including PowerShell modules, scripts, and DSC resources.
    URL/Link
    Powershell Commands
    $xyz commands don't have Microsoft description links as normally these aren't global cmdlets
    Default Call Example:
    Verb-Noun -Parameter Argument
    Command
    $host
    Shows information about the actual connection
    The version shown here is the PowerShell Version from the Host Application and not from PowerShell itself
    $pshome
    Displays the folder of the current PowerShell DLL
    $PSVersionTable
    Use this to determine the engine version
    If the variable does not exist, it is safe to assume the engine is version 1.0
    Add-PhysicalDisk
    This command will add a disk to a storage pool
    Enter-PSSession (alias ETSN)
    The cmdlet starts an interactive session with a single remote computer
    During the session, the commands that you type run on the remote computer, just as if you were typing directly on the remote computer
    You can have only one interactive session at a time.
    Get-Command
    The Get-Command cmdlet gets all commands that are installed on the computer, including cmdlets, aliases, functions, filters, scripts, and applications
    Get-Command gets the commands from PowerShell modules and commands that were imported from other sessions
    To get only commands that have been imported into the current session, use the ListImported parameter
    Instead of displaying all the commands you can just display the cmdlets:
    Get-Command -CommandType Cmdlet
    Get-Verb
    The Get-Verb function gets verbs that are approved for use in PowerShell commands
    read-host 'TEXT'
    The cmdlet reads a line of input from the console
    You can use it to prompt a user for input
    Because you can save the input as a secure string, you can use this cmdlet to prompt users for secure data, such as passwords, as well as shared data
    PowerShell Aliases
    Aliases for different PowerShell Commands
    Command Alias
    Cmdlet Name
    Description of Command
    sion
    Where-Object
    Selects objects from a collection based on their property values.
    ForEach-Object
    Performs an operation against each item in a collection of input objects.
    ac
    Add-Content
    Appends content, such as words or data, to a file.
    asnp
    Add-PSSnapIn
    Adds one or more Windows PowerShell snap-ins to the current session.
    cat
    Get-Content
    Gets the contents of a file.
    cd
    Set-Location
    Sets the current working location to a specified location.
    chdir
    Set-Location
    clc
    Clear-Content
    Deletes the contents of an item, but does not delete the item.
    clear
    Clear-Host
    Clears the display in the host program.
    clhy
    Clear-History
    Deletes entries from the command history.
    cli
    Clear-Item
    clp
    Clear-ItemProperty
    Deletes the value of a property but does not delete the property.
    cls
    Clear-Host
    clv
    Clear-Variable
    Deletes the value of a variable.
    cnsn
    Connect-PSSession
    Reconnects to disconnected sessions
    compare
    Compare-Object
    Compares two sets of objects.
    copy
    Copy-Item
    Copies an item from one location to another.
    cp
    Copy-Item
    cpi
    Copy-Item
    cpp
    Copy-ItemProperty
    Copies a property and value from a specified location to another location.
    curl
    Invoke-WebRequest
    Gets content from a webpage on the Internet.
    cvpa
    Convert-Path
    Converts a path from a Windows PowerShell path to a Windows PowerShell provider path.
    dbp
    Disable-PSBreakpoint
    Disables the breakpoints in the current console.
    del
    Remove-Item
    Deletes files and folders.
    diff
    Compare-Object
    dir
    Get-ChildItem
    Gets the files and folders in a file system drive.
    dnsn
    Disconnect-PSSession
    Disconnects from a session.
    ebp
    Enable-PSBreakpoint
    Enables the breakpoints in the current console.
    echo
    Write-Output
    Sends the specified objects to the next command in the pipeline. If the command is the last command in the pipeline, the objects are displayed in the console.
    epal
    Export-Alias
    Exports information about currently defined aliases to a file.
    epcsv
    Export-Csv
    Converts objects into a series of comma-separated (CSV) strings and saves the strings in a CSV file.
    epsn
    Export-PSSession
    Imports commands from another session and saves them in a Windows PowerShell module.
    erase
    Remove-Item
    etsn
    Enter-PSSession
    Starts an interactive session with a remote computer.
    exsn
    Exit-PSSession
    Ends an interactive session with a remote computer.
    fc
    Format-Custom
    Uses a customized view to format the output.
    fl
    Format-List
    Formats the output as a list of properties in which each property appears on a new line.
    foreach
    ForEach-Object
    ft
    Format-Table
    Formats the output as a table.
    fw
    Format-Wide
    Formats objects as a wide table that displays only one property of each object.
    gal
    Get-Alias
    Gets the aliases for the current session.
    gbp
    Get-PSBreakpoint
    Gets the breakpoints that are set in the current session.
    gc
    Get-Content
    gci
    Get-ChildItem
    gcm
    Get-Command
    Gets all commands.
    gcs
    Get-PSCallStack
    Displays the current call stack.
    gdr
    Get-PSDrive
    Gets drives in the current session.
    ghy
    Get-History
    Gets a list of the commands entered during the current session.
    gi
    Get-Item
    Gets files and folders.
    gjb
    Get-Job
    Gets Windows PowerShell background jobs that are running in the current session.
    gl
    Get-Location
    Gets information about the current working location or a location stack.
    gm
    Get-Member
    Gets the properties and methods of objects.
    gmo
    Get-Module
    Gets the modules that have been imported or that can be imported into the current session.
    gp
    Get-ItemProperty
    Gets the properties of a specified item.
    gps
    Get-Process
    Gets the processes that are running on the local computer or a remote computer.
    group
    Group-Object
    Groups objects that contain the same value for specified properties.
    gsn
    Get-PSSession
    Gets the Windows PowerShell sessions on local and remote computers.
    gsnp
    Get-PSSnapIn
    Gets the Windows PowerShell snap-ins on the computer.
    gsv
    Get-Service
    Gets the services on a local or remote computer.
    gu
    Get-Unique
    Returns unique items from a sorted list.
    gv
    Get-Variable
    Gets the variables in the current console.
    gwmi
    Get-WmiObject
    Gets instances of Windows Management Instrumentation (WMI) classes or information about the available classes.
    h
    Get-History
    history
    Get-History
    icm
    Invoke-Command
    Runs commands on local and remote computers.
    iex
    Invoke-Expression
    Runs commands or expressions on the local computer.
    ihy
    Invoke-History
    Runs commands from the session history.
    ii
    Invoke-Item
    Performs the default action on the specified item.
    ipal
    Import-Alias
    Imports an alias list from a file.
    ipcsv
    Import-Csv
    Creates table-like custom objects from the items in a CSV file.
    ipmo
    Import-Module
    Adds modules to the current session.
    ipsn
    Import-PSSes
    Imports commands from another session into the current session.
    irm
    Invoke-RestMethod
    Sends an HTTP or HTTPS request to a RESTful web service.
    ise
    powershell_ise.exe
    Explains how to use the PowerShell_ISE.exe command-line tool.
    iwmi
    Invoke-WMIMethod
    Calls Windows Management Instrumentation (WMI) methods.
    iwr
    Invoke-WebRequest
    Gets content from a web page on the Internet.
    kill
    Stop-Process
    Stops one or more running processes.
    lp
    Out-Printer
    Sends output to a printer.
    ls
    Get-ChildItem
    man
    help
    Displays information about Windows PowerShell commands and concepts.
    md
    mkdir
    Creates a new item.
    measure
    Measure-Object
    Calculates the numeric properties of objects, and the characters, words, and lines in string objects, such as files of text.
    mi
    Move-Item
    Moves an item from one location to another.
    mount
    New-PSDrive
    Creates temporary and persistent mapped network drives.
    move
    Move-Item
    mp
    Move-ItemProperty
    Moves a property from one location to another.
    mv
    Move-Item
    nal
    New-Alias
    Creates a new alias.
    ndr
    New-PSDrive
    ni
    New-Item
    Creates a new item.
    nmo
    New-Module
    Creates a new dynamic module that exists only in memory.
    npssc
    New-PSSessionConfigurationFile
    Creates a file that defines a session configuration.
    nsn
    New-PSSession
    Creates a persistent connection to a local or remote computer.
    nv
    New-Variable
    Creates a new variable.
    ogv
    Out-GridView
    Sends output to an interactive table in a separate window.
    oh
    Out-Host
    Sends output to the command line.
    popd
    Pop-Location
    Changes the current location to the location most recently pushed to the stack. You can pop the location from the default stack or from a stack that you create by using the Push-Location cmdlet.
    ps
    Get-Process
    pushd
    Push-Location
    Adds the current location to the top of a location stack.
    pwd
    Get-Location
    r
    Invoke-History
    rbp
    Remove-PSBreakpoint
    Deletes breakpoints from the current console.
    rcjb
    Receive-Job
    Gets the results of the Windows PowerShell background jobs in the current session.
    rcsn
    Receive-PSSession
    Gets results of commands in disconnected sessions.
    rd
    Remove-Item
    rdr
    Remove-PSDrive
    Deletes temporary Windows PowerShell drives and disconnects mapped network drives.
    ren
    Rename-Item
    Renames an item in a Windows PowerShell provider namespace.
    ri
    Remove-Item
    rjb
    Remove-Job
    Deletes a Windows PowerShell background job.
    rm
    Remove-Item
    rmdir
    Remove-Item
    rmo
    Remove-Module
    Removes modules from the current session.
    rni
    Rename-Item
    rnp
    Rename-ItemProperty
    Renames a property of an item.
    rp
    Remove-ItemProperty
    Deletes the property and its value from an item.
    rsn
    Remove-PSSession
    Closes one or more Windows PowerShell sessions (PSSessions).
    rsnp
    Remove-PSSnapin
    Removes Windows PowerShell snap-ins from the current session.
    rujb
    Resume-Job
    Restarts a suspended job
    rv
    Remove-Variable
    Deletes a variable and its value.
    rvpa
    Resolve-Path
    Resolves the wildcard characters in a path, and displays the path contents.
    rwmi
    Remove-WMIObject
    Deletes an instance of an existing Windows Management Instrumentation (WMI) class.
    sajb
    Start-Job
    Starts a Windows PowerShell background job.
    sal
    Set-Alias
    Creates or changes an alias (alternate name) for a cmdlet or other command element in the current Windows PowerShell session.
    saps
    Start-Process
    Starts one or more processes on the local computer.
    sasv
    Start-Service
    Starts one or more stopped services.
    sbp
    Set-PSBreakpoint
    Sets a breakpoint on a line, command, or variable.
    sc
    Set-Content
    Replaces the contents of a file with contents that you specify.
    select
    Select-Object
    Selects objects or object properties.
    set
    Set-Variable
    Sets the value of a variable. Creates the variable if one with the requested name does not exist.
    shcm
    Show-Command
    Creates Windows PowerShell commands in a graphical command window.
    si
    Set-Item
    Changes the value of an item to the value
