  2. WEB Development
  3. Wordpress
WordPress Plugins
  • 27 October 2025 at 08:18
    Hei lëschten ech Iech e puer wichteg Plugins fir WordPress an an Zukunft nach mei ob.
    Wann der Iech eng Säit fir ären Club maacht sinn des ganz wichteg (ech erklären iwwerall em wat et genau geet).
    Here you will find an interesting list of plugins, components or themes for CMS like Joomla or Wordpress.
    URL
    Name
    URL
    3D FlipBook
    3D FlipBook allows to browse images, PDFs or HTMLs as flipping book. It can be used for demonstration magazines, books, cards, brochures, booklets and much more in natural way. It helps to attract user attention and make more impression on him.
    URL
    Advanced Custom Fields
    Customise WordPress with powerful, professional and intuitive fields.
    URL
    Advanced noCaptcha & invisible Captcha
    Zeigt noCaptcha oder unsichtbares Captcha in Kommentar-Formularen (hinter den Kommentarfeld und vor dem Senden-Button), Contact Form 7, bbPress, BuddyPress, WooCommerce, Anmeldung, Registrierung, bei verlorenem Passwort und beim Passort zurücksetzen. Es kann auch leicht in jedes andere Formular eingebunden werden.
    URL
    Auto Amazon Links
    Formerly, Amazon Auto Links. The plugin generates links of Amazon products just coming out today. You just pick categories and they appear even in JavaScript disabled browsers.
    URL
    Back Button Widget
    Back button widget for WordPress
    URL
    Better Search Replace
    A lightweight migration plugin for WordPress
    URL
    Blog Filter – Post Filters Post Portfolio Gallery
    The Blog Filter is best post filtering plugin for WordPress. You can filters posts using category and tag filters.
    Blog filter has a really simple and easy to use (user-friendly) interface. It can filter your blog posts according to categories and tags. All your posts will be shown in beautiful grid layout. Just click on any category/tag filter, and it will filter posts instantly. This feature can help visitors to get the filtered content easily which they are looking for. it is so easy to use for both beginner and expert users because you don’t have to do anything, just install and activate the plugin. You can generate the shortcode and paste it where you want to show blog post filtering or post portfolio. It will automatically fetch all blog and categories itself.
    Many options are available to configure color and button color, show/hide title, show/hide Details/Permalink/Gallery buttons etc. It also has option to select image quality so you could load smaller or bigger images whatever is required according to your needs.
    URL
    CAPTCHA 4WP
    Easily add any type of CAPTCHA (such as noCaptcha or invisible Captcha) on any website form, including login pages, comments and password reset forms, and also forms by third party plugins such as Contact Form 7, WooCommerce & BuddyPress.
    URL
    Code Widget
    Code Widget is simple widget allow you to insert any arbitrary Text/HTML and run PHP Code or Short Code. This Widget parse PHP code into simple text and much more.
    Only users with the unfiltered_html role will be allowed to insert unfiltered HTML. This includes PHP code, so users without admin or editor permissions will not be able to use this to execute code, even if they have widget editing permissions.
    URL
    Comments – wpDiscuz
    AJAX realtime comment system with custom comment form and fields. Designed to supercharge WordPress native comments. Super fast and responsive with dozens of features. This is the best alternative to Disqus and Jetpack Comments, if you want to keep your comments in your database.
    URL
    Conditional Menus
    Conditional Menus is a simple yet useful WordPress plugin developed by Themify, which allows you to swap the menus in the theme as per specific conditions. In short, you can have different menus in different posts, pages, categories, archive pages, etc. It works with any WordPress theme that uses the standard WordPress menu function.
    URL
    Cooked – Recipe Plugin
    Cooked is the absolute best way to create & display recipes with WordPress. SEO optimized (rich snippets), galleries, cooking timers, printable recipes and much more.
    URL
    Cool Timeline Pro
    Cool Timeline Pro is an advanced WordPress timeline plugin that showcases your life history timeline or your company’s story timeline in a responsive horizontal or vertical chronological order based on the year and the date of your posts. It is best plugin to create a timeline theme. You can also convert your blog posts into a blog timeline by using this awesome timeline template maker plugin.
    URL
    Date Published Shortcode
    The short description really says it all. No bullshit, no complex stuff, just a simple shortcode that you can copy and paste to save a few seconds. I really made this so that I wouldn’t have to glance at the date every time that I posted an article; quite lazy, I know, but automating stuff is cool, and now I at least know how to put up a plugin on the WordPress repository.
    URL
    Gmedia Photo Gallery
    Manage files, show image galleries and photo slideshows, play music on your site with Gmedia Gallery plugin. Gmedia Gallery plugin provides a comprehensive interface for handling galleries, images, video & audio files. With Gmedia Gallery plugin you can upload an unlimited number of photo and audio files, create dozens of galleries and playlists, group pictures and other files in albums, add tags for each file. Handle any file format and link any files with images in few clicks. You can import images with captions from Worpress Media Library, Flagallery plugin and from NextGen Gallery plugin right to Gmedia Library.
    URL
    Knowledge Base for Documentation and FAQs
    The Best WordPress Knowledge Base Plugin
    URL
    Memphis Documents Library
    Memphis Documents Library (mDocs) is a documents library for WordPress with a robust feature set. It is a great tool for the organization and distribution of files.
    URL
    Ninja Tables Pro – The Fastest and Most Diverse WP DataTables Plugin
    Ninja Tables is the Best Selling WordPress table builder plugin with a user-friendly layout, easy to use settings, and enticing front-end. Build a table right from the comfort without having any coding experience. Do whatever you want – create, edit, maintain and customize. Ninja Tables is the ultimate solution for designing WordPress tables for any purpose.
    URL
    PDF Image Generator
    By uploading a PDF attachment, this plugin convert the cover page to jpeg and attach it as a post thumbnail file. It also allows displaying a thumbnail icon and inserting PDF link with a cover image into the editor.
    URL
    Redirection
    Manage redirects with WordPress
    URL
    Responsive Lightbox & Gallery
    Want to create engaging, stunning, responsive galleries for your WordPress website? Interested in making the most of images, videos, and galleries on your site? Then you need the Responsive Lightbox and Gallery plugin!
    URL
    Responsive Tabs
    Responsive Tabs PRO will allow you to display tabbed content on your website. This is useful for arranging content-heavy pages into a set of tabs. Thanks to the tab/accordion system, your content will be divided into sections that you can show/hide by clicking the tabs. This plugin is responsive and will turn into an accordion when chosen breakpoint is reached.
    URL
    The GDPR Framework By Data443
    Data443 Risk Mitigation, Inc., has secured the global technology, branding, and ongoing management rights to leading WordPress GDPR solution: The WordPress GDPR Framework.
    The WordPress GDPR Framework is an open source plugin that operates with the world’s leading web hosting and content management ecosystem – WordPress. WordPress powers roughly 50 to 60 percent of the world’s content management and e-commerce sites with over 20,000,000 organizations using the open-source software for their primary corporate website, a significant number of which deliver e-commerce services.
    Globally, millions of organizations are subject to data privacy laws such as the EU’s General Data Privacy Regulation (GDPR), yet many organizations don’t have a significant existing capability for compliance. The WordPress GDPR Framework delivers easy-to-use tools that help organizations speed GDPR and other data privacy compliance.
    URL
    The SEO Framework
    You don’t need more clicks that bounce. You need more clicks that pay.
    Join over 150 000 businesses and grow using proven SEO tactics.
    URL
    Titan Anti-spam & Security
    Titan includes anti-spam, firewall, malware scanner, site accessibility checking, security and threats audits for WordPress websites. Our security functions provide Titan with the latest firewall rules, malware signatures, and database of malicious IP addresses – all you need to ensure the security of your website.
    Titan is a comprehensive WordPress security solution, completed by a set of additional features as add-ons, which was placed into a simple and intuitive interface.
    URL
    Tooltip Glossary for WordPress | Knowledge Base Plugin
    WordPress Tooltip Plugin is the best WordPress knowledge base plugin to host a glossary of terms or information repository on WordPress
    Build an online dictionary, encyclopedia, wiki, or glossary, with the best WordPress Glossary plugin out there! Enjoy this mobile-friendly plugin with AMP support, alphabetical index and SEO features!
    URL
    Video Gallery – Vimeo and YouTube Gallery
    Origin code has been working on an ultimate video gallery plugin for months. And you can already check the results.
    A responsive multifunctional video gallery plugin with multiple ways and designs for uploading and displaying a video.load the plugin on your WordPress dashboard and create any of these video galleries:
    YouTube Gallery
    Vimeo Gallery
    Video Gallery Mix
    URL
    Visitor Traffic Real Time Statistics
    isitor Traffic Real Time Statistics is a Counter and statistics plugin for WordPress to display your WordPress blog statistics and traffic. Ranging from general total statistics
    This plugin will help you to track your visitors, browsers, operating systems, visits and much more..
    When it comes to ease of use, Visitor Traffic Real Time Statistics comes in first, You will have a real Counter and statistics plugin for your WordPress website..
    This plugin will help you to track your visitors, browsers, operating systems, visits and much more in one dashboard page..
    URL
    Wordfence Security – Firewall & Malware Scan
    Wordfence includes an endpoint firewall and malware scanner that were built from the ground up to protect WordPress. Our Threat Defence Feed arms Wordfence with the newest firewall rules, malware signatures and malicious IP addresses it needs to keep your website safe. Rounded out by 2FA and a suite of additional features, Wordfence is the most comprehensive WordPress security solution available.
    URL
    WP Links Page Pro
    A WordPress plugin that allows you to create a dynamic link gallery with screenshots of each link. It will automatically create screenshots of each link and save you from creating a hardcoded links page or finding images for each site. It allows sites to create a links page with several different views. The screenshots for the links can be updated on a set schedule and with the click of a button. WP Links Page Pro will also fetch the favicon and meta title/description for your displays.
    URL
    WP Server Health Stats
    WP Server Health Stats plugin will give you the ability to monitor your WordPress site at its core level. With all-important server health stats like allocated PHP memory, memory usage, realtime RAM usage, CPU usage etc. you can always identify if something wrong is going on with your site.
    Now you don’t have to contact your host every single time for minor things. You can easily see the server health stats in your WP admin dashboard and make critical decisions based on that, like if enabling some plugin is consuming a lot of memory or CPU etc.
    URL
    wp-stardate
    A powerful versitale lightweight stardate plugin with a wide array of functionalities for integrating stardates with your wordpress blog.
    URL
    YotuWP - YouTube Gallery
    The longer you keep vistors on website, the better. Video was a game-changer for us personally in regards to keeping people on the site longer.
    YotuWP is your solution for embeding videos YouTube on your website. YotuWP is modern and mobile responsive video gallery. Easy embed videos from YouTube video playlist, channel and videos IDs to your WordPress website.
Similar Threads
  • DSGVO konform (Germany)?
    • 26 October 2025 at 12:22
    • Web Development in general
  • Google Fonts DSGVO - Lokale EinbindungGoogle Fonts DSGVO - Lokale Einbindung
    • 26 October 2025 at 12:16
  • Wordpress, wpForo & EnlighterJS
    • 26 October 2025 at 12:02
    • Wordpress
  • 44 Today
  • 44 This Week
  • 421 This Month
  • 60.449 This Year
  • 60.449 Total
Last updated: 2 November 2026 at 02:36
